enable isis
enable isis {area area_name}
Description
This command enables the specified IS-IS router process on the current virtual router.
Syntax Description
area_name Specifies the name of the IS-IS router process to be enabled.
Default
Disabled.
Usage Guidelines
If no area name is specified, all IS-IS router processes on the current virtual router are enabled. Once a router process is enabled, IS-IS PDUs are sent and processed provided that the following conditions are met:
  • The router process has a system ID and area address configured.
  • At least one associated VLAN interface has IPv4 or IPv6 forwarding enabled.
This command has no effect on router processes that are already enabled.
The following command enables the IS-IS process named areax:
enable isis area areax
Platform Availability
This command is available on all platforms with a Premier or Extreme Platform ONE license as described in the licensing guide.
