Configures the AS-external LSA limit and overflow duration associated with OSPF database overflow handling.
| number | Specifies the number of external routes that can be held in a link-state database. |
| seconds | Specifies a duration for which the system has to remain in the overflow state. |
The default for timeout is 0, which indicates that once the router goes into overflow state, it stays there until OSPF is disabled and then re-enabled.
Not applicable.
The following command configures the AS-external LSA limit and overflow duration:
configure ospf ase-limit 50000 timeout 1800
This command is available on all platforms with a Base license or higher as described in the licensing guide.
