show ospfv3 virtual-link
show ospfv3 virtual-link {{routerid} router_identifier {area} area_identifier}
Description
Displays virtual link(s) information.
Syntax Description
router_identifier Specifies a router identifier, a four-byte, dotted decimal number.
area_identifier Specifies an OSPFv3 area, a four-byte, dotted decimal number.
Default
N/A.
Usage Guidelines
Router-identifier—Router ID for the other end of the link.
Area-identifier—Transit area used for connecting the two end-points. The transit area cannot have an area identifier of 0.0.0.0 and cannot be a stub or NSSA area.
The following command displays information about the virtual link to a particular router:
# show ospfv3 virtual-link
Neighbor Router ID  : 0.0.0.3            Transit Area ID     : 0.0.0.1
Hello Interval      : 10s                Router Dead Interval: 40s
Retransmit Interval : 5s                 Transit Delay       : 1s
Instance ID         : 0                  Via Interface       : intf2
State               : P2P                Num of State Changes: 1
Hello Due in        : 2                  Number of Events    : 2
Hellos Rxed         : 149                Hellos Txed         : 148
DB Description Rxed : 2                  DB Description Txed : 2
LSA Request Rxed    : 1                  LSA Request Txed    : 1
LSA Update Rxed     : 2                  LSA Update Txed     : 2
LSA Ack Rxed        : 2                  LSA Ack Txed        : 1
In Discards         : 0
Local Address       : 2001:20::1
Remote Address      : 2001:20::2
Restart Helper      : None
Restart Helper Strict LSA Checking: Enabled
Authentication      : IPsec ESP
SPI                 : 500                Algorithm           : HMAC-SHA-512
Encrypted Key String: #$bC0GrQHhqjeDABqYwnlfdihIsOhV9g==
Virtual Neighbor:
   RtrId: 0.0.0.3  IpAddr: 2001:20::2  Type: Auto
   State: FULL  DR: 0.0.0.0  BDR: 0.0.0.0  Dead Time: 38
   Options: 0x13 (-|R|-|-|E|V6)
The following command displays information about the OSPFv3 virtual link authentication with default (none) configuration (line 19):
In Discards         : 0
Authentication      : None
Virtual Neighbor:
IPsec Authentication information was added in ExtremeXOS 31.2.
Authentication Trailer information was added in ExtremeXOS 31.3.
Platform Availability
This command is available on all platforms with a Base license or higher as described in the licensing guide.
