Displays status and version information for the OpenAPI server.
N/A.
Use this command to view the current state and operational status of the OpenAPI server. The output displays:
State Values:
Enabled (by user) - Server enabled by user commandEnabled (by IQAgent) - Server enabled by IQAgentEnabled (by IQAgent and user) - Server enabled by bothDisabled - Server is disabledServer Status Values:
Healthy - Server is running normallyUnhealthy - Server is running but experiencing issuesBooting - Server is starting upStopped - Server is not runningFailed - Server failed to start or crashedVersion Information:
Version and Schema Version fields display N/A if the application is missing or version information cannot be loaded.
For more detailed diagnostic information, use the debug openapi show command.
The following command displays OpenAPI server information:
show openapi
Sample output when enabled by user:
State : Enabled (by user) Server Status : Healthy Version : 1.4.12.16 Schema Version : 0.2.0
Sample output when required by IQAgent:
State : Enabled (by IQAgent) Server Status : Healthy Version : 1.4.12.16 Schema Version : 0.2.0
Sample output when disabled:
State : Disabled Server Status : Stopped Version : 1.4.12.16 Schema Version : 0.2.0
Sample output during server startup:
State : Enabled (by user) Server Status : Booting Version : 1.4.12.16 Schema Version : 0.2.0
This command was first available in version 33.6.1.
