enable bootprelay ipv6
enable bootprelay {ipv4 | ipv6} {vlan vlan_name} | {vr vr_name} | all {vr vr_name}
Description
Enables BOOTP Relay v6. This can be done across the VR or on a per VLAN basis.
Syntax Description
bootprelay BOOTP Relay service.
ipv4 DHCPv4 BOOTP Relay service.
ipv6 DHCPv6 BOOTP Relay service.
vlan_name Specifies a VLAN name
vr Uses a specific virtual router name.
vr_name Specifies a virtual router name.
all Enables all VLANs.
Default
IPv4.
Usage Guidelines
Use this command to enable BOOTP Relay across the VR or on a per VLAN basis.
The following example displays IPv6 bootprelay information:
* switch #  show bootprelay ipv6
BOOTP Relay: DHCPv6 BOOTP Relay enabled on virtual router "VR-Default"
    BOOTP Relay Servers : 2001:0db8:85a3:0000:0000:8a2e:0370:7334
                          2001:0db8:85a3:0000:0000:8a2e:0370:7335
                          2001:0db8:85a3:0000:0000:8a2e:0370:7336
                          2001:0db8:85a3:0000:0000:8a2e:0370:7337
VLAN "Default":
   BOOTP Relay          : Disabled
VLAN "v1":
   BOOTP Relay          : Enabled
   BOOTP Relay Servers  : 2001:0db8:85a3:0000:0000:8a2e:0370:7338
   Interface ID         : v1-12
   Remote ID            :v1_remId
   Prefix Snooping      : Disabled
VLAN"v2":
   BOOTP Relay Servers  : 2001:0db8:85a3:0000:0000:8a2e:0370:7339
   Interface ID         : 100 (Default)
   Remote ID            : 00:04:96:52:A7:1B (Default)
This command was first available in ExtremeXOS 15.5.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.6.1 Licensing Guide document.
