configure ospfv3 area cost
configure ospfv3 area area_identifier cost [automatic | cost]
Description
Configures the cost of sending a packet to all interfaces belonging to an area.
Syntax Description
area_identifier Specifies an OSPFv3 area, a four-byte, dotted decimal number.
automatic Determine the advertised cost from the OSPFv3 metric table.
cost Specifies the cost metric. Range is 1 to 65535.
Default
The default cost is automatic.
Usage Guidelines
Use this command to set the cost of the links belonging to area manually, if the default cost needs to be overwritten. The interface cost is advertised as the link cost in router-LSA.
The following command configures the cost of area 0.0.0.1 to 10. All the links of this area will inherit the area's cost value of 10.
configure ospfv3 area 0.0.0.1 cost  10
Platform Availability
This command is available on all platforms with a Base license or higher as described in the licensing guide.
