Disables redistribution of routes to OSPF.
| bgp | Specifies BGP routes. |
| direct | Specifies direct routes. |
| Specifies Inter-VR leaked direct routes. | Specifies Inter-VR leaked direct routes. |
| host-mobility | Specifies host mobility. |
| e-bgp | Specifies E-BGP routes. |
| i-bgp | Specifies I-BGP routes. |
| rip | Specifies RIP routes. |
| static | Specifies static routes. |
| isis | Specifies IS-IS routes. |
| isis-level-1 | Specifies ISIS Level 1 routes. |
| isis-level-1-external | Specifies ISIS Level 1 External routes. |
| isis-level-2 | Specifies ISIS Level 2 routes. |
| isis-level-2-external | Specifies ISIS Level 2 External routes. |
The default setting is disabled.
Use this command to stop OSPF from exporting routes derived from other protocols.
The following command disables OSPF to export BGP-related routes to other OSPF routers:
disable ospf export bgp
This command is available on all platforms.
