configure pim delete tunnel
configure pim {ipv4} delete tunnel [tunnel_name | tunnel all]
Description
Disables PIM on a router interface.
Syntax Description
ipv4 Specifies the IPv4 address family.
delete Specifies to delete PIM on a VLAN.
tunnel Specifies the tunnel name.
tunnel_name Specifies to configure PIM information for interface.
all Specifies to configure PIM information on all Layer 3 interfaces.
Default
N/A.
Usage Guidelines
Use this command to disable PIM for a specific or all tunnels.
The following example disables PIM on tunnel accounting:
configure pim delete tunnel accounting
This command was first available in ExtremeXOS 32.3.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.6.1 Licensing Guide document.
