configure radius tls cipher
configure radius tls cipher [[ cipher | fips_cipher | all ] on | [ cipher | fips_cipher] off ]
Description
This command turns on/off ciphers for RADIUS Transport Layer Security (TLS) sessions.
Syntax Description
tlsSpecifies Transport Layer Security (TLS).
cipherSpecifies configuring the algorithm to use for encrypting RADIUS TLS sessions.
cipherSpecifies the cipher name.
fips_cipherSpeciies the FIPS compliant cipher name.
allSpecifies all ciphers available.
on Specifies enabling the specified cipher (Default).
offSpecifies disabling the specified cipher.
Default
On.
Usage Guidelines
The following ciphers are supported:
Default mode -
FIPS mode -
The following example enables cipher TLS_RSA_WITH_AES_128_CBC_SHA for RADIUS TLS servers:
# configure radius tls cipher TLS_RSA_WITH_AES_128_CBC_SHA on
This command was first available in version 33.3.1.
Platform Availability
