show private-vlan name
show {private-vlan} name
Description
Displays information about the specified PVLAN.
Syntax Description
name Specifies the name of the PVLAN to display.
Default
N/A.
Usage Guidelines
If the PVLAN is incomplete because it does not have a network or any subscriber VLAN configured, [INCOMPLETE] appears next to the PVLAN name.
The following example output displays information for the companyx PVLAN:
# show private-vlan "Engineering"
Name            VID  Protocol Addr        Flags                Proto  Ports  Virtual
Active router
/Total
Engineering
Network VLAN:
-Engr1         10   --------------------------------------   ANY    4 /5   VR-Default
Non-Isolated Subscriber VLAN:
-ni1           400  --------------------------------------   ANY    1 /1   VR-Default
-ni2           401  -------------------------------------    ANY    1 /1   VR-Default
-i1            500  -------------------------------------    ANY    1 /1   VR-Default
Flags : (C) EAPS Control vlan, (d) NetLogin Dynamically created VLAN,
(D) VLAN Admin Disabled, (E) ESRP Enabled, (f) IP Forwarding Enabled,
(i) ISIS Enabled, (I) IP Forwarding lpm-routing Enabled, (L) Loopback Enabled,
(l) MPLS Enabled, (m) IPmc Forwarding Enabled, (n) IP Multinetting Enabled,
(N) Network LogIn vlan, (o) OSPF Enabled, (p) PIM Enabled,
(P) EAPS protected vlan, (r) RIP Enabled,
(T) Member of STP Domain, (V) VPLS Enabled, (v) VRRP Enabled
Platform Availability
This command is available on all platforms that support the Private VLAN feature. For features and the platforms that support them, see the Switch Engine v33.6.1 Licensing Guide document.
