clear ospf counters
clear ospf counters { interfaces [all | vlan vlan_name | area area-identifier] | area [all | area-identifier] | virtual-link [all | router-identifier area-identifier] | neighbor [all | routerid [ip-address {ip-mask} | ipNetmask] | vlan vlan_name]| system}
Description
Clears the OSPF counters (statistics).
Syntax Description
vlan_name Specifies a VLAN name.
router-identifier Specifies a router interface number.
area-identifier Specifies an OSPF area.
ip-address Specifies an IP address
ip-mask Specifies a subnet mask.
ipNetmask Specifies IP address / Netmask.
system Specifies the OSPF system counters.
Default
N/A.
Usage Guidelines
The global command clear counters also clears all OSPF counters. This global command is the equivalent of clear ospf counters for OSPF.
The following command clears the OSPF counters for area 1.1.1.1:
clear ospf counters area 1.1.1.1
Platform Availability
This command is available on all platforms with a Base license or higher as described in the licensing guide.
