clear mld snooping
clear mld snooping {{vlan} name}
Description
Removes one or all MLD snooping entries.
Syntax Description
name Specifies a VLAN name.
Default
N/A.
Usage Guidelines
This command can be used by network operations to manually remove MLD snooping entries instantly. However, removing an MLD snooping entry can disrupt the normal forwarding of multicast traffic until the snooping entries are learned again.
The static and dynamic MLD snooping entries are removed, and then recreated upon the next general query. The static router entry is removed and recreated immediately.
The following command clears MLD snooping from VLAN accounting:
clear mld snooping accounting
Platform Availability
This command is available on the platforms listed for the IPv6 multicast routing feature in the Switch Engine v33.6.1 Licensing Guide document.
