clear counters mpls ldp
clear counters mpls ldp {{{vlan} vlan_name} | lsp all}
Description
Clears LDP control protocol counters and packet and byte counters associated with LDP LSPs.
Syntax Description
vlan_name Clears LDP control protocol counters on the specified VLAN.
vlan all Clears LDP control protocol counters on all MPLS interfaces.
lsp all Clears all LDP LSP packet and byte counters.
Default
N/A.
Usage Guidelines
By default, all LDP control protocol counters are cleared for all LDP interfaces and all byte counters. Specifying the vlan keyword clears only the protocol counters associated with a specified LDP interface. Specifying the lsp keyword clears only the packet and byte counters associated with LDP LSPs.
This example clears all LDP control protocol counters and all packet and byte counters for all LDP LSPs:
This command was first available in ExtremeXOS 11.6.
Platform Availability
This command is available only on the platforms that support this feature as described in the Switch Engine v33.6.1 Licensing Guide document.
