unconfigure sflow collector
unconfigure sflow collector {ipaddress} ipaddress {port udp-port-number} {vr vr_name}
Description
Unconfigures the sFlow collector.
Syntax Description
ipaddress Specifies the IP address of the collector to reset.
udp-port-number Specifies the UDP port.
vr_name
Specifies which virtual router.
Note: User-created VRs are supported only on the platforms listed for this feature in the Switch Engine v33.6.1 Licensing Guide document.
Default
The following values are the defaults for this command:
  • UDP port number—6343
  • Virtual router—VR-Mgmt (previously called VR-0)
Usage Guidelines
This command allows you to reset the specified sFlow collector parameters to the default values.
Both the commands unconfigure ports monitor vlan and unconfigure sflow collector will reset the collector parameters to the default.
The following command removes the collector at IP address 192.168.57.1:
unconfigure sflow collector ipaddress 192.168.57.
This command was first available in ExtremeXOS 11.0.
Platform Availability
