clear isis counters vlan
clear isis counters [vlan all | {vlan} vlan_name]
Description
This command clears all IS-IS counters for one or all VLANs.
Syntax Description
vlan all Clears the counters for all VLANs.
vlan_name Specifies a single VLAN for which counters are cleared.
Default
N/A.
Usage Guidelines
This command only affects VLANs that have been added to IS-IS router processes. The following counters are cleared: adjacency changes, adjacency initialization failures, rejected adjacencies, ID field length mismatches, maximum area address mismatches, authentication type failures, authentication failures, DIS changes, hello PDU TX and RX count, LSP TX and RX count, CSNP TX and RX count, PSNP TX and RX count, unknown PDU type TX and RX count.
The following command clears the IS-IS counters for all VLANs:
clear isis counters vlan all
Platform Availability
This command is available on all platforms with a Premier or Extreme Platform ONE license as described in the licensing guide.
