show bandwidth pool
show bandwidth pool [ingress | egress | duplex] vlan vlan_name
Description
Displays the configured bandwidth pool settings for the specified VLAN.
Syntax Description
ingress Displays configured bandwidth pool settings for incoming traffic only.
egress Displays configured bandwidth pool settings for outgoing traffic only.
duplex Displays configured bandwidth pool settings for traffic in both directions.
vlan_name Displays configured bandwidth pool settings only for the specified VLAN.
Default
N/A.
Usage Guidelines
This command displays the configured bandwidth pool settings for a VLAN. Values displayed include the VLAN, maximum reserveable bandwidth (both ingress and egress), and bandwidth reserved by application and by priority level.
The following command displays bandwidth pool settings and accepted bandwidth reservations for all ports:
show bandwidth pool duplex vlan vlan_1
# show bandwidth pool duplex vlan vlan_1
(mbps)  Rsvd CIRBW  Cmmt  Cmmt CIRBW
Vlan         Dir   Phy    BE Limit Pools Total Avail
vlan_1        Rx  1000     0  1000   300   300   700
Tx  1000     0  1000   500   500   500
(mbps)   CIRBW Available in Pool (per priority level)
Appl  Dir  Pool     0     1     2     3     4     5     6     7
mpls   Rx   300   300   300   290   290   290   290   290   290
Tx   500   500   500   491   491   491   491   491   491
(Rx)-Receive, (Tx)-Transmit  (BE)-Best Effort
This command was first available in ExtremeXOS 11.6.
Platform Availability
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.6.1 Licensing Guide document.
