configure policy profile
configure policy profile profile_index {name name} {pvid pvid} {pvid-status pvid_status} {cos cos} {cos-status cos_status} {egress-vlans egress_vlan_list}{forbidden-vlans forbidden_vlans} {untagged-vlans untagged_vlans} {append | clear} {tci-overwrite tci_overwrite} {precedence [precedence | default]} {auth-override auth_override} {nsi [nsi | none]} {web-redirect web_redir_index} {access-list [unassigned | list_name | list_name_placeholder]}
Description
Creates a policy profile entry.
Syntax Description
profile_indexPolicy ID (1-63).
namePolicy profile name.
nameProfile name string 1-64 characters.
pvid-statusPVID status (enable/disable).
pvidPVID value (0-4,095). Default is 1, which specifies Default VLAN.
cos-statusCoS status (enable/disable).
cosClass of Service value (0-255).
egress-vlansEgress VLAN list (1-4094).
forbidden-vlanForbidden VLAN list (1–4,094).
untagged-vlansUntagged VLAN list (1-4,094).
appendAppend to one of Egress, Forbidden, Untagged VLAN list.
clearClear from one of Egress, Forbidden, Untagged VLAN list.
tci_overwrite
TCI-overwrite status (enable/disable).
Note: The ExtremeSwitching 5520 platform does not support TCI-overwrite.
Note: With tci-overwrite disabled, you can only add a VLAN to incoming packets that are untagged or priority tagged (priority set, but vlan=0).
auth-overrideConfigures authentication override using a port profile attribute. No further authentication occurs on the port if enabled.
auth_overrideAuthentication override status: "enable" or "disable". Default is disabled.
precedence
Specifies setting the policy classification rule precedence.
Note: You cannot set a precedence if the rule model is set for ACL Style Policy (access-list). To set the rule model, use the command configure policy rule-model [access-list | hierarchical].
precedence
Sets the rule precedence (for example: 1–2, 10, 12–18, 20–23, 25, 31).
To see the supported rules, use show policy profile {all | profile_index} {detail} .
defaultSets the default rule precedence, rather than a custom one (1–2, 10, 12–19, 23, 20–22, 25, 31).
web-redirectConfigures web-redirect.
web_redir_indexConfigures a web redirect index (range = 1–10). Default is 0, which is disabled.
nsiNetwork Service Identifier. For Fabric Attach and VXLAN (VNI = NSI), provides a mechanism to apply the VLAN/NSI mappings in policy using a profile-based attribute.
nsiNSI 24-bit value ranging from 1 to 16,777,215.
noneNo NSI for the VLAN (default).
access-listDesignates assigning an access list to this profile.
unassignedRemoves an assigned access list (default).
list_nameSelects the access list name to assign to this profile. Type the access-list name as shown in the provided list.
list_name_placeholderAllows you to provide an access-list name that does not currently exist to assign to this profile.
Default
If optional parameters are not specified, none are applied.
Web direct is disabled by default.
The default for NSI is none.
If no PVID value is given, the default is 1 (Default VLAN).
If you do not set a policy classification rule precedence, the default order is used (1–2, 10, 12–19, 23, 20–22, 25, 31).
By default, not access list is assigned to a profile.
Usage Guidelines
Use this command to create a policy profile entry.
This example shows how to create a policy profile 1 named "netadmin" with PVID override enabled for PVID 10, and Class-of-Service override enabled for CoS 5. This profile can use VLAN 10 for untagged egress:
# configure policy profile 1 name netadmin pvid-status enable pvid 10 cos-status enable cos 5 untagged-vlans 10
This command was first available in ExtremeXOS 16.1.
The authentication override parameter was added in ExtremeXOS 22.2.
The NSI keyword was added in ExtremeXOS 22.5.
Policy classification rule precedence re-ordering was added in ExtremeXOS 30.2.
Access list capability was added in ExtremeXOS 30.5.
Platform Availability
