enable isis hello-padding
enable isis [vlan all | {vlan} vlan_name] hello-padding
Description
This command enables the padding of hello PDUs on one or all VLANs.
Syntax Description
vlan all Enables hello padding on all IS-IS VLANs.
vlan_name Specifies a single VLAN on which hello padding is enabled.
Default
Enabled.
Usage Guidelines
When hello padding is enabled, IS-IS pads hello packets to the interface MTU. This is used among neighbors to verify that adjacencies have the same MTU configured on either end. The disadvantage of hello padding is the price of bandwidth consumed by larger packets.
The following command enables hello padding on the SJvlan VLAN:
enable isis SJvlan hello-padding
Platform Availability
This command is available on all platforms with a Premier or Extreme Platform ONE license as described in the licensing guide.
