configure isis metric
configure isis [vlan all | {vlan} vlan_name] metric metric {level[1|2]}
Description
This command sets the narrow metric for one or all IS-IS VLANs.
Syntax Description
vlan all Applies the configuration to all IS-IS VLANs.
vlan_name Specifies a single VLAN to which the configuration applies.
metric metric Sets the metric value. The range is 1 to 63.
level [1 | 2] Limits the configuration to either level 1 or level 2. If neither level 1 nor level 2 is specified, the configuration applies to both levels.
Default
10.
Usage Guidelines
If narrow metrics are enabled, this value is used in the associated LSPs for the selected VLANs.
The following command sets the narrow metric for all IS-IS VLANs to 15:
configure isis vlan all metric 15
Platform Availability
This command is available on all platforms with a Premier or Extreme Platform ONE license as described in the licensing guide.
