enable flowmon group
enable flowmon group group_name
Description
Enables a Flow Monitor group.
Syntax Description
group Specifies the Flow Monitor group.
group_nameSpecifies the assigned name of the Flow Monitor group. Range is 32 characters.
Default
N/A.
Usage Guidelines
While a group is being enabled, it can't be modified except to add or delete keys.
Before a group can be enabled, it must have at least one key and one collector added to it. A template key portion is present once a key has been added.
The following command enables a Flow Monitor group with the name 'max-flow-age':
# enable flowmon group max-flow-age
This command was first available in ExtremeXOS 32.2.
Platform Availability
This command is available on 5420, 5520, and 5720 series switches.
