disable mvr
disable mvr
Description
Disables MVR on the system.
Syntax Description
Default
Disabled.
Usage Guidelines
None.
The following example disables MVR on the system:
disable mvr
This command was first available in ExtremeXOS 11.4.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the MVR feature, see the Switch Engine v33.6.1 Licensing Guide document.
