Displays the MPLS QoS profile to EXP value mappings and the status of MPLS EXP replacement (enabled or disabled).
This command has no arguments or keywords.
N/A.
This command displays MPLS QoS profile to EXP value mappings and the status of MPLS EXP replacement (enabled or disabled). These values are set using the configure mpls exp replacement qosprofile command and can be resent using the unconfigure mpls exp replacement command.
The following is an example of the output of the show mpls exp replacement command:
* BD-10K.28 # show mpls exp replacement QoS Profile --> EXP mapping: QP1 --> 00 QP2 --> 01 QP3 --> 02 QP4 --> 03 QP5 --> 04 QP6 --> 05 QP7 --> 06 QP8 --> 07 EXP Replacement is disabled
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.6.1 Licensing Guide document.
