show upm event
show upm event event-type
Description
Displays UPM events of the specified type.
Syntax Description
event-type Displays events of the specified type for all profiles. Valid values for event-type are:device-detectdevice-removeuser-authenticateuser-unauthenticated.
Default
N/A.
Usage Guidelines
Use this command to display the following types of events:
  • device-detect
  • device-remove
  • user-authenticate
  • user-unauthenticated
The following command displays device-detect events:
show upm event device-detect
The output of the command is similar to the following:
UPM Profile                   PortList
profile1                         3
This command was first available in ExtremeXOS 11.6.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the Universal Port feature, see the Switch Engine v33.6.1 Licensing Guide document.
