configure pim state-refresh
configure pim {ipv4 | ipv6} state-refresh {vlan} [vlan_name | all] [on | off]
Description
Enables or disables the PIM-DM state refresh feature on one or all VLANs.
Syntax Description
ipv4 Specifies the IPv4 address family.
ipv6 Specifies the IPv6 address family.
vlan_name Specifies a VLAN on which to enable or disable the PIM-DM state refresh feature.
on Enables the PIM-DM state refresh feature on the specified VLANs.
off Disables the PIM-DM state refresh feature on the specified VLANs.
Default
Disabled.
Usage Guidelines
When this feature is disabled on an interface, the interface behaves as follows:
  • State refresh messages are not originated.
  • State refresh messages received on the interface are dropped without processing.
  • State refresh messages received on other interfaces are not forwarded to the disabled interface.
The following example enables the PIM-DM state refresh feature on VLAN blue:
configure pim state-refresh blue on
This command was first available in ExtremeXOS 12.4.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.6.1 Licensing Guide document.
