show macsec usage
show macsec usage
Description
Displays a per-port view of MAC Security (MACsec) usage information.
Syntax Description
usage Specifies to display per-port MACsec usage information.
Default
N/A.
Usage Guidelines
Displays the number of ports that have MACsec enabled, and the maximum number of ports allowed, per slot. This command also displays the amount of bandwidth consumed by the enabled ports (assumes maximum throughput), as well as the maximum bandwidth allowed.
If the switch type has no port limit, then the "Port Count Limit" is displayed as N/A. If the switch has no bandwidth limit, then the "Bandwidth Maximum" is also displayed as N/A.
The CLI prevents you from exceeding the port limit but not the bandwidth limit. If the instantaneous traffic across all MACsec-enabled ports exceeds the switch's bandwidth limit, then excess traffic will be dropped.
The following example shows MACsec usage information:
# show macsec usage
	   ----Port Count----  ------Bandwidth-----
Slots     #Enabled     Limit  Allocated    Maximum
Slot-1           1        48    1.0Gbps   50.0Gbps
The following example shows MACsec usage information on ports 1-5:
# show macsec ports 1-5 usage
                     Subject
               Link  to BW     MACsec   Allocated
Port          Speed  Maximum?  Enabled  Bandwidth
1           1.0Gbps  Yes       No               -
2           1.0Gbps  Yes       No               -
3           1.0Gbps  Yes       No               -
4           1.0Gbps  Yes       No               -
5           1.0Gbps  Yes       No               -
This command was first available in ExtremeXOS 31.5.
Platform Availability
This command is available on the following platforms.
The MACsec feature requires the installation of the MAC Security feature pack license.
PlatformPorts
5120All ports of all models except stacking ports.
5320All ports of all models except stacking ports.
5420All ports of all models except stacking ports.
5520All ports, except 5520-VIM-4X and 5520-24X 10G ports
5720All ports of all models except stacking ports.
Extreme 7520-48YE-8CEAll front-panel ports.
