Enables OSPFv3 for the router.
N/A.
When OSPFv3 is enabled, it will start exchanging Hellos on all of it's active interfaces. It will also start exporting routes into OSPFv3 routing domain from other protocols, if enabled.
When OSPFv3 is disabled, it will release all the run-time allocated resources like adjacencies, link state advertisements, run-time memory, etc.
The following command enables OSPFv3 for the router:
enable ospfv3
This command is available on all platforms with a Base license or higher as described in the licensing guide.
