disable isis restart-helper
Description
This command disables the IS-IS restart helper.
Syntax Description
Default
Enabled.
Usage Guidelines
When this feature is disabled, the router does not act as a restart helper and may time out a restarting router‘s adjacency per normal operation.
The following command disables the IS-IS restart helper:
Platform Availability
This command is available on all platforms with a Premier or Extreme Platform ONE license as described in the licensing guide.
