Resets one or all OSPF interfaces to the default settings.
| vlan-name | Specifies a VLAN name. |
| area-identifier | Specifies an OSPF area. |
N/A.
ExtremeXOS OSPF allows you to change certain configurable OSPF parameters on the fly. This command selectively resets the configurable parameters to their default values. Following is the list of parameters whose values will be reset to their defaults:
The following command resets the OSPF interface to the default settings on the VLAN accounting:
unconfigure ospf accounting
This command is available on all platforms with a Base license or higher as described in the licensing guide.
