clear isis counters area
clear isis counters area [area_name | all]
Description
This command clears all IS-IS counters for the specified router process or all router processes.
Syntax Description
area_name Specifies the router process for which counters are cleared.
all Clears IS-IS counters for all router processes.
Default
N/A.
Usage Guidelines
The following counters are cleared: corrupted LSPs, LSPDB overloads, manual address from area count, LSP sequence number wraps, LSP sequence number skips, LSP purges, partition changes, SPF calculations, authentication type failures, authentication failures, and ID field length mismatches.
The following command clears the IS-IS counters for areax:
clear isis counters area areax
Platform Availability
This command is available on all platforms with a Premier or Extreme Platform ONE license as described in the licensing guide.
