show ipstats ipv6
show ipstats ipv6 [{vlan name | tunnel tunnel_name}]
Description
Displays IPv6 statistics handled by the CPU for the switch for a particular VLAN.
Syntax Description
name Specifies a VLAN name.
tunnel_name Specifies a tunnel name.
Default
N/A.
Usage Guidelines
This command only shows statistics of the CPU-handled packets. Not all packets are handled by the CPU. For example, packets forwarded in hardware do not increment the statistics counters.
The following example displays IPv6 statistics for the VLAN accounting:
show ipstats ipv6 vlan accounting
The VR option was removed in ExtremeXOS 30.1.
Platform Availability
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.6.1 Licensing Guide document.
