ip
Configures IP default gateway
priority
- Access Points — AP410i/e, AP460i/e,
AP505i, AP510i/e, AP560i/h, AP7522, AP7532, AP7562, AP7612, AP7632, AP7662, AP8432,
AP8533
Syntax
ip default-gateway priority <1-8000>
Parameters
| default-gateway | Configures the default gateway |
| priority <1-8000> | Sets the priority for the default gateway acquired via OSPF- <1-8000> –
Specify an integer from 1 - 8000. The default is 7000.
Note: Lower the value,
higher is the priority.
nx9500-6C8809(config-profile default-ap8533-router-ospf)#ip default-gateway priority 1
nx9500-6C8809(config-profile default-ap8533-router-ospf)#show context
router ospf
area 0.0.0.4
auto-cost reference-bandwidth 1
default-information originate metric 1 metric-type 2
