Enables File Transfer Protocol (FTP) on this management policy. FTP is the
standard protocol for transferring files over a TCP/IP network. FTP requires
administrators enter a valid username and password authenticated locally. FTP access is
disabled by default.
Optional. Configures a new user account on the FTP server. The FTP user
file lists users with FTP server access.
<USERNAME> –
Specify the username. The username should not exceed 32 characters in
length.
password [1 <ENCRYPTED-PASSWORD>|<PASSWORD>]
Configures an encrypted password
1
<ENCRYPTED-PASSWORD> – Specifies an encrypted password (use this
option if copy pasting from another device). The password should not
exceed 63 characters in length.
<PASSWORD> -
Configures a clear text password
rootdir <DIR>
After specifying the password, configure the FTP root directory.
rootdir <DIR> –
Configures the root directory for FTP logins. Specify the root
directory path.
Usage Guidelines
The string size of an encrypted password (option 1, password is
encrypted with a SHA1 algorithm) must be exactly 40 characters. Copy paste the encrypted
password here.
nx9500-6C8809(config-management-policy-test)#ftp username superuser password test@123 rootdir dir
nx9500-6C8809(config-management-policy-test)#show context
management-policy test
http server
ftp username superuser password 1 f617ca50c59fb47028f96db4baab5f3d8f03c03ab257960b0fd127c69f02cd7e rootdir dir
no ssh
aaa-login radius external
aaa-login radius policy test
banner motd "Have a Good Day"
