Configures an AirDefense sensor server resource for client terminations and WIPS event logging. This is the server that supports WIPS events on behalf of the controller or service platform.
sensor-server <1-3> ip <IP/HOSTNAME> {port [443|<1-65535>]}
Parameters
sensor-server <1-3>
Sets a numerical index to differentiate this AirDefense sensor server from other servers. A maximum of 3 (three) sensor server resources can be defined.
ip <IP/HOSTNAME>
Configures the AirDefense sensor server‘s IP address or hostname
<IP/HOSTNAME> – Specify the IP address.
Optional. Configures the port. The options are:
443 – The default port used by the AirDefense server. This is the default setting.
<1-65535> – Manually sets the port number of the AirDefense server from 1 - 65535
nx9500-6C8809(config-device-94-9B-2C-13-3E-1C)#sensor-server 1 ip 172.16.10.7
nx9500-6C8809(config-device-94-9B-2C-13-3E-1C)#show context
ap505 94-9B-2C-13-3E-1C
use profile default-ap505
use rf-domain default
hostname TechPubAP505
floor 5thfloor
layout-coordinates 1.0 2.0
license AP aplicenseley@1234 aplicensekey@123
rsa-key ssh rsa-key1
location SanJose
no contact
country-code us
channel-list 2.4GHz 1,2
override-wlan test vlan-pool 8
mac-name 94-9B-2C-13-3E-1C 5.8TestAP
neighbor-info-interval 50
