eguest-server (VX9000 only)
Profile Config Commands
Enables the ExtremeGuest (EGuest) server
The ExtremeWireless WiNG EGuest solution is an independently installable VM/Server that provides integrated guest management and analytics. Use this command to enable the EGuest daemon on the EGuest server.
EGuest being a licensed feature, ensure that the EGUEST-DEV license is applied on the EGuest server‘s self context. For more information, see license.
Syntax
eguest-server
Parameters
eguest-server
eguest-server
Note: Execute this command, without the ‘host‘ option, on the EGuest server. When executed, the EGuest daemon is enabled on the host.
EGuest server can be hosted only a VX 9000 platform.
On the EGuest server, execute the command without the ‘host‘ option to enable the EGuest daemon.
EG-Server(config-device-02-EE-1A-7E-AE-5B)#eguest-server
EG-Server(config-device-02-EE-1A-7E-AE-5B)#show context include-factory | include eguest-server
 eguest-server
Related Commands
noDisables the EGuest server by stopping the EGuest daemon
