smart-ocs-monitoring {awareness-override|client-aware|extended-scan-frequency| frequency|off-channel-duration|power-save-aware|sample-count|tx-load-aware|voice-aware}
smart-ocs-monitoring {awareness-override [schedule|threshold]}
smart-ocs-monitoring {awareness-override schedule <1-3> <START-TIME> <END-TIME> <DAY>}
smart-ocs-monitoring {awareness-override threshold <10-10000>}
smart-ocs-monitoring {client-aware [2.4GHz|5GHz|6GHz] <1-255>}
smart-ocs-monitoring {extended-scan-frequency [2.4GHz|5GHz|6GHz] <0-50>}
smart-ocs-monitoring {frequency [2.4GHz|5GHz|6GHz] <1-120>}
smart-ocs-monitoring {off-channel-duration [2.4GHz|5GHz|6GHz] <20-150>}
smart-ocs-monitoring {power-save-aware [2.4GHz|5GHz|6GHz] [disable|dynamic|strict]}
smart-ocs-monitoring {sample-count [2.4GHz|5GHz|6GHz] <1-15>}
smart-ocs-monitoring {tx-load-aware [2.4GHz|5GHz|6GHz] <1-100>}
smart-ocs-monitoring {voice-aware [2.4GHz|5GHz|6GHz] [disable|dynamic|strict]}
| awareness-override | Optional. Use this parameter to configure client awareness settings overrides |
| schedule <1-3> <START-TIME> <END-TIME> {<DAY>} | Configures a time and day schedule when awareness settings are overridden
| awareness-override threshold <10-10000> | Optional. Use this parameter to configure client awareness settings overrides
| client-aware | Optional. Enables client aware scanning on this Smart RF policy Use this parameter to configure a client threshold number. When the number of clients connected to a radio equals this threshold number, Use this parameter to configure a client threshold number. When the number of clients connected to a radio equals the specified threshold, the radio avoids channel scanning. The radio does not change channel even if needed (based on the interference recovery determination made by the smart master). This feature is disabled by default. |
| 2.4GHz <1-255> | Enables client aware scanning on the 2.4 GHz band Avoids radio scanning when a specified minimum number of clients are present
| 5GHz <1-255> | Enables client aware scanning on the 5.0 GHz band Avoids radio scanning when a specified minimum number of clients are present
| 6GHz <1-255> | Enables client aware scanning on the 6.0 GHz band Avoids radio scanning when a specified minimum number of clients are present
| extended-scan-frequency | Optional. Enables an extended scan, as opposed to a neighbor only scan, on this Smart RF policy. This is the frequency radios use to scan for non-peer radios. |
| 2.4GHz <0-50> | Enables extended scan on the 2.4 GHz band
| 5GHz <0-50> | Enables extended scan on the 5.0 GHz band
| 6GHz <0-50> | Enables extended scan on the 6.0 GHz band
| frequency | Optional. Specifies the scan frequency. This is the frequency, in seconds, in which smart-ocs-monitoring changes channels for an off-channel scan. |
| 2.4GHz <1-120> | Selects the 2.4 GHz band
| 5GHz <1-120> |
Selects the 5.0 GHz band
| 6GHz <1-120> |
Selects the 6.0 GHz band
| off-channel-duration | Optional. Specifies the duration to scan off channel This is the duration for which an access point radio remains off-channel. During this period the radio monitors devices within the network and, if necessary, perform self healing and neighbor recovery to compensate for coverage area losses within a RF Domain. |
| 2.4GHz <20-150> | Selects the 2.4 GHz band (in milliseconds)
| 5GHz <20-150> | Selects the 5.0 GHz band (in milliseconds)
| 6GHz <20-150> | Selects the 6.0 GHz band (in milliseconds)
| power-save-aware | Optional. Enables power save awareness scanning mode on this Smart RF policy. The options are: disable, dynamic, and strict. This setting allows Smart RF to detect power save clients and take them into consideration when performing off channel scans. Strict disables smart monitoring as long as a power save capable client is associated to a radio. Dynamic disables smart monitoring as long as there is data buffered for a power save client at the radio. |
| 2.4GHz [disable|dynamic|strict] | Sets power save aware scanning mode on the 2.4 GHz band
| 5GHz [disable|dynamic|strict] | Sets power save aware scanning mode on the 5.0 GHz band
| 6GHz [disable|dynamic|strict] | Sets power save aware scanning mode on the 6.0 GHz band
| sample-count | Optional. Specifies the number of samples to collect before reporting an issue to the Smart RF master |
| 2.4GHz <1-15> | Selects the 2.4 GHz band
| 5GHz <1-15> | Selects the 5.0 GHz band
| 6GHz <1-15> | Selects the 6.0 GHz band
| tx-load-aware | Optional. Specifies a transmit load percentage that serves as a threshold before scanning is avoided for an access point‘s 2.4 GHz, 5.0 GHz, or 6.0 GHz band. This option is disabled for 2.4 GHz, 5.0 GHz, or 6.0 GHz bands. |
| 2.4GHz <1-100> | Selects the 2.4 GHz band
| 5GHz <1-100> | Selects the 5.0 GHz band
| 6GHz <1-100> | Selects the 6.0 GHz band
| voice-aware | Optional. Enables voice awareness scanning mode on this Smart RF policy. The options are: disable, dynamic, and strict. Strict disables smart monitoring as long as a voice client is associated to a radio. Dynamic disables smart monitoring as long as there is data buffered for a voice client at the radio. |
| 2.4GHz [disable|dynamic|strict] | Specifies the scanning mode on the 2.4 GHz band
| 5GHz [dynamic|strict] | Specifies the scanning mode on the 5.0 GHz band
| 6GHz [dynamic|strict] | Specifies the scanning mode on the 6.0 GHz band
nx9500-6C8809(config-smart-rf-policy-test)#smart-ocs-monitoring extended-scan-frequency 2.4GHz 9
nx9500-6C8809(config-smart-rf-policy-test)#smart-ocs-monitoring awareness-override schedule 1 12:30 20:30
nx9500-6C8809(config-smart-rf-policy-test)#show context smart-rf-policy test group-by floor sensitivity custom assignable-power 2.4GHz max 20 assignable-power 2.4GHz min 8 channel-list 2.4GHz 1,12 channel-width 5GHz auto channel-width 2.4GHz auto area test channel-list 2.4GHz 1,2,3 avoidance-time dfs 300 no smart-ocs-monitoring smart-ocs-monitoring frequency 5GHz 3 smart-ocs-monitoring frequency 2.4GHz 3 smart-ocs-monitoring sample-count 5GHz 3 smart-ocs-monitoring extended-scan-frequency 5GHz 0 smart-ocs-monitoring extended-scan-frequency 2.4GHz 9 smart-ocs-monitoring awareness-override schedule 1 12:30 20:30 all interference-recovery client-threshold 255 interference-recovery channel-switch-delta 5GHz 5 --More-- nx9500-6C8809(config-smart-rf-policy-test)#
| no (smart-rf-policy-config-mode-command) | Disables off-channel monitoring |
