Configures ARP and DHCP related security parameters on this port-channel interface
Supported in the
following platforms:
Service Platforms —
NX5500, NX7500, NX9500, NX9600, VX9000
Syntax
ip [arp|dhcp]ip arp [header-mismatch-validation|trust]ip dhcp trust
Parameters
trust]
Configures ARP related parameters on this port-channel interface
header-mismatch-validation – Enables a source MAC mismatch check in both the ARP and ethernet headers. This option is enabled by default.
trust – Enables ARP trust on this port channel. If enabled, ARP packets received on this port are considered trusted, and information from these packets is used to identify rogue devices. This option is disabled by default.
ip dhcp trust
ip dhcp trust
Enables DHCP trust. If enabled, only DHCP responses are trusted and forwarded on this port channel, and a DHCP server can be connected only to a DHCP trusted port. This option is enabled by default.
nx9500-6C8809(config-profile-testNX9000-if-port-channel1)#ip arp trust
nx9500-6C8809(config-profile-testNX9000-if-port-channel1)#show context
interface port-channel1
description "This port-channel is for enabling dynamic LACP."
duplex full
ip arp trust
