guest-database-backup
Enables periodic backup of a captive portal guest registration user database. This option is enabled by default.
Supported on the following platforms:
Syntax
guest-database-backup enable {<TIME>}
Parameters
guest-database-backup enable {<TIME>}Enables periodic backup of a captive portal guest registration user database. This command also allows you to configure the time at which the system starts backing up the database. The default backup-start time is ‘00:00‘ (midnight every day).
  • <TIME> – Optional. Resets the periodic database backup-start time to a user-defined value in the HH;MM format. When specified, the system starts periodic backup of the database, every day, at the specified time.
nx9500-6C8809(config-guest-management-test)#guest-database-backup enable 12:30
nx9500-6C8809(config-guest-management-test)#show context
guest-management test
Related Commands
no (guest-management-policy-config-commands)Disables periodic backup of a captive portal‘s guest registration user database
