This chapter summarizes MiNT policy commands in the CLI command structure.
All communication using the MiNT transport layer can be optionally secured. This includes confidentiality, integrity and authentication of all communications. In addition, a device can be configured to communicate over MiNT with other devices authorized by an administrator.
Use the (config) instance to configure mint-policy related configuration commands. To navigate to the config MiNT policy instance, use the following command:
<DEVICE>(config)#mint-policy global-default
nx9500-6C8809(config-mint-policy-global-default)#? Mint Policy Mode commands: level Mint routing level lsp LSP mtu Configure the global Mint MTU no Negate a command or set its defaults router Mint router udp Configure mint UDP/IP encapsulation clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-mint-policy-global-default)#
Section contents:
