Configures the deny-threshold and
rssi-threshold values. These threshold values are considered when responding to a client‘s
association/authentication request.
Configures the number of times association/authentication request, from a
client, is ignored if the RSSI is less than the configured RSSI threshold. This
option is disabled by default.
<1-12> – Specify the
deny-threshold from 1 - 12.
rssi-threshold <-100--40>
Configures an association response RSSI threshold value. If the RSSI is below
the configured threshold value, the client‘s association/authentication request is
ignored. This option is disabled by default. rssi-threshold
