proxy-arp-mode
Enables proxy ARP mode for handling ARP requests. Proxy ARP is the technique used to answer ARP requests intended for another system. By faking its identity, the access point accepts responsibility for routing packets to the actual destination.
Access
Points: AP3000 /X, AP5010 , AP310i/e , AP410i/e , AP505i , AP510i , AP510e , AP560i , AP7602 , AP7612 , AP7622 , AP7632 , AP7662 , AP8163 , AP8533 . Service Platforms: NX5500, NX7500, NX9500, NX9600 Virtual Platforms : CX9000, VX9000
Syntax
proxy-arp-mode [dynamic|strict]
Parameters
proxy-arp-mode Enables proxy ARP mode for handling ARP requests. The options available are dynamic and strict. dynamic Forwards ARP requests to the wireless side (for which a response could not be proxied) strict Does not forward ARP requests to the wireless side
nx9500-6C8809 (config-wlan-test)#proxy-arp-mode strict
nx9500-6C8809 (config-wlan-test)#show context
wlan test
ssid test
bridging-mode local
encryption-type none
authentication-type none
protected-mgmt-frames mandatory
wing-extensions wmm-load-information
client-load-balancing probe-req-intvl 5ghz 5
client-load-balancing band-discovery-intvl 2
acl exceed-rate wireless-client-denied-traffic 20 disassociate
broadcast-dhcp validate-offer
http-analyze controller
