passpoint-policy
Creates a new passpoint policy and enters its configuration mode. The passpoint policy implements the Hotspot 2.0 Wi-Fi Alliance standard, enabling interoperability between clients, infrastructure, and operators. It makes a portion of the IEEE 802.11u standard mandatory and adds Hotspot 2.0 extensions that allow clients to query a network before actually attempting to join it.
The passpoint policy allows a single or set of Hotspot 2.0 configurations to be global and referenced by the devices that use it. It is mapped to a WLAN. However, only primary WLANs on a BSSID will have their passpoint policy configuration used.
Syntax
passpoint-policy <POLICY-NAME>
Parameters
passpoint-policy <POLICY-NAME>Specify the passpoint policy name. If a passpoint policy with the specified name does not exist, it is created.
nx9500-6C8809(config)#passpoint-policy test
nx9500-6C8809(config-passpoint-policy-test)#?
Passpoint Policy Mode commands:
  3gpp                   Configure a 3gpp plmn (public land mobile network) id
  access-network-type    Set the access network type for the passpoint
  connection-capability  Configure the connection capability for the passpoint
  domain-name            Add a domain-name for the passpoint
  hessid                 Set a homogeneous ESSID value for the passpoint
  internet               Advertise the passopint having internet access
  ip-address-type        Configure the advertised ip-address-type
  nai-realm              Configure a NAI realm for the passpoint
  net-auth-type          Add a network authentication type to the passpoint
  no                     Negate a command or set its defaults
  operator               Add configuration related to the operator of the
                         passpoint
  osu                    Online signup
  roam-consortium        Add a roam consortium for the passpoint
  venue                  Set the venue parameters of the passpoint
  wan-metrics            Set the wan-metrics of the passpoint
  clrscr                 Clears the display screen
  commit                 Commit all changes made in this session
  do                     Run commands from Exec mode
  end                    End current mode and change to EXEC mode
  exit                   End current mode and down to previous mode
  help                   Description of the interactive help system
  revert                 Revert changes
  service                Service Commands
  show                   Show running system information
  write                  Write running configuration to memory or terminal
Related Commands
no Removes an existing passpoint policy
For more information, see Passpoint Policy.
