smart-sensor-status-timer
This timer works in conjunction with smart-sensor. The timer function is handled exclusively by the RF domain manager (RFDM). When the timer expires, the RFDM checks radio sensor status. If all sensors are "Off", recalibration for smart-sensor is triggered.
Smart-sensor auto-trigger must be enabled (default) for the timer feature to work.
The following events result in a start/restart of the timer:
Supported on the following devices
Syntax
smart-sensor-status-timer <1-48>
Parameters
smart-sensor-status-timerEnables the timer for the sensor status check.
<1 – 48>Sets the timer expiration (in hours). Once the timer expires, the sensor status check begins.
nx9500-6C8809(config-smart-rf-policy-test)#smart-sensor-status-timer 36
Related Commands
sh smart-sensor automatic-trigger-status on <Domain Name>Displays the smart-sensor recalibration status for the specified RF domain.
show wireless radio on <Domain Name>Displays the radio sensor status for the specified RF domain.
no (smart-rf-policy-config-mode-command)Disables the smart-sensor-status-timer feature.
