virtual-machine
Displays the virtual-machine (VM) configuration, logs, and statistics
- Service Platforms — NX 95XX, NX 96XX
Syntax
show virtual-machine [configuration|debugging|export|statistics]
show virtual-machine [configuration|statistics] {<VM-NAME>|team-urc|team-rls| team-vowlan} {(on <DEVICE-NAME>)}
show virtual-machine debugging {level|on}
show virtual-machine debugging {level [debug|error|info|warning]} {on <DEVICE-NAME>}
show virtual-machine export <VM-NAME> {on <DEVICE-NAME>}
show virtual-machine [configuration|statistics] {<VM-NAME>|adsp|team-cmt}
Parameters
| virtual-machine | Displays the following VM-related information: configuration or statistics |
| configuration | Displays detailed VM configuration |
| statistics | Displays VM statistics |
| [<VM-NAME>| team-urc|team-rls| team-vowlan] | The following keywords are common to the ‘configuration‘ and ‘statistics‘ parameters:- VM-NAME> – Optional. Displays VM configuration or statistics for the virtual machine identified by the <VM-NAME> keyword. Specify the VM name.
- team-urc – Optional. Displays TEAM-URC (IP-PBX) VM configuration/statistics
- team-rls – Optional. Displays TEAM-RLS (Radio Link Server) VM configuration/statistics<
- team-vowlan – Optional. Displays TEAM-VoWLAN (Voice over WLAN) VM configuration/statistics
| on <DEVICE-NAME> | Specifies the name of the device on which the command is executed- <DEVICE-NAME> – Specify the name of the service platform.
show virtual-machine [configuration|statistics] {<VM-NAME>|adsp|team-cmt} {(on <DEVICE-NAME>)}
| [<VM-NAME>|adsp| team-cmt] | The following keywords are common to the ‘configuration‘ and ‘statistics‘ parameters:- VM-NAME> – Optional. Displays VM configuration or statistics for the virtual machine identified by the <VM-NAME> keyword. Specify the VM name.
- adsp – Optional. Displays Air-Defense Services Platform (ADSP) VM configuration/statistics
- team-cmt – Optional. Displays TEAM-CMT VM configuration/statistics
show virtual-machine debugging {level[debug|error|info|warning]} {on <DEVICE-NAME>}
| debugging | Displays VM debugging logs |
| level [debug| error|info|warning] | Optional. Displays VM debugging logs based on the level selected. The available options are:- debug – Displays VM logs of level debug and above
- error – Displays VM logs of level error
- info – Displays VM logs of level Info and above
- warning – Displays logs of level warning and above
| export | Displays VM configuration export related information |
| <VM-NAME>] | Displays VM configuration export related information for the virtual machine identified by the <VM-NAME> keyword. Specify the VM name. The NX 95XX and NX 96XX series service platforms will display ADSP and TEAM-CMT VM configuration export information.
nx9500-6C874D#show virtual-machine statistics
NAME STATE VCPUS MEM (MB) BRIDGE-IF IP
WiNG - - 18432 - -
adsp Halted - - unknown -
team-cmt Halted - - unknown -
nx9500-6C874D#
nx9500-6C874D#show virtual-machine configuration
NAME AUTOSTART MEMORY(MB) VCPUS
WiNG - 18432 -
adsp ignore 12000 12
team-cmt ignore 1024 1
nx9500-6C874D#
nx9500-6C874D>show virtual-machine statistics adsp
VM name: adsp
Base Version : unknown
Install Status : not_installed
nx9500-6C874D>
