Use the (config) instance to configure IKEv1/IKEv2 peer configuration commands. To navigate to the IKEv1/IKEv2 peer config instance, use the following commands:
<DEVICE>(config)#profile <DEVICE-TYPE> <PROFILE-NAME> <DEVICE>(config-profile-<PROFILE-NAME>)#crypto ikev1/ikev2 peer <IKEV1/IKEV2-PEER-NAME> nx9500-6C8809(config-profile-default-nx5500)#crypto ikev1 peer peer1 nx9500-6C8809(config-profile-default-nx5500-ikev1-peer-peer1)#? Crypto IKEV1 Peer Configuration commands: authentication Configure Authentication credentials ip Configure peer address/fqdn localid Set local identity no Negate a command or set its defaults remoteid Configure remote peer identity use Set setting to use clrscr Clears the display screen commit Commit all changes made in this session end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-profile-default-nx5500-ikev1-peer-peer1)# nx9500-6C8809(config-profile-default-nx5500)#crypto ikev2 peer peer1 nx9500-6C8809(config-profile-default-nx5500-ikev2-peer-peer1)#? Crypto IKEV2 Peer Configuration commands: authentication Configure Authentication credentials ip Configure peer address/fqdn localid Set local identity no Negate a command or set its defaults remoteid Configure remote peer identity use Set setting to use clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-profile-default-nx5500-ikev2-peer-peer1)#
The following table summarizes crypto IPSec IKEv1/IKEv2 peer configuration mode commands:
| Command | Description |
| authentication | Configures a peer‘s authentication mode and the pre-shared key |
| ip | Configures the peer‘s IP address |
| localid | Configures a peer‘s local identity details |
| remoteid | Configures a remote peer‘s identity details |
| use | Associates an IKEv1 policy and IKEv2 policy with the IKEv1 and IKEv2 peer respectively |
| no | Negates a command or reverts settings to their default. The no command, when used in the ISAKMP policy mode, defaults the ISAKMP protection suite settings. |
Section contents:
