Configures filters for this neighbor. These filters are BGP IP ACL, IP prefix list, AS path list, and route map. Based on the filters used, updates received from this neighbor are filtered.
Service Platforms — NX9500, NX9600
Syntax
use [distribute-list <BGP-IP-ACL-NAME>|filter-list <AS-PATH-LIST-NAME>|
prefix-list <IP-PREFIX-LIST-NAME>|route-map <BGP-ROUTE-MAP-NAME>]
Parameters
Uses predefined and configured filters with this neighbor
distribute-list <BGP-IP-ACL-NAME> – Uses a BGP IP ACL
<BGP-IP-ACL-NAME> – Specify the BGP IP ACL name.
filter-list <AS-PATH-LIST-NAME> – Uses an AS path list
<AS-PATH-LIST-NAME> – Specify the AS path list name.
prefix-list <IP-PREFIX-LIST-NAME> – Uses a IP prefix list
<IP-PREFIX-LIST-NAME> – Specify the IP prefix list name.
route-map <BGP-ROUTE-MAP-NAME> – Uses a route map
<BGP-ROUTE-MAP-NAME> – Specify the route map name.
nx9500-6C8809
(config-device B4-C7-99-6C-88-09-router-bgp-neighbor-192.168.13.99)#use filter-list FilterList_01 in
nx9500-6C8809
(config-device B4-C7-99-6C-88-09-router-bgp-neighbor-192.168.13.99)#use route-map testBGPRouteMap out
nx9500-6C8809
(config-device B4-C7-99-6C-88-09-router-bgp-neighbor-192.168.13.99)#show context
bgp neighbor 192.168.13.99
remote-as 199
maximum-prefix 9999 80 restart 50
unsuppress-map test
nx9500-6C8809
