ipv6
Displays IPv6 related information and statistical data
Syntax
show ipv6 [default-gateways|delegated-prefix|dhcp|hop-limit|interface|mld|
name-server|neighbors|route]
show ipv6 [default-gateways|delegated-prefix|hop-limit|name-server]
{on <DEVICE-NAME>}
show ipv6 dhcp [client received-options|relay status|status]
{on <DEVICE-NAME>}
show ipv6 interface {<IF-NAME>|brief} {(on <DEVICE-NAME>)}
show ipv6 mld snooping [mrouter vlan <1-4095>|querier vlan <1-4095>|vlan <1-4095>]
{on <DEVICE-NAME>}
show ipv6 neighbors <VLAN-NAME> {(on <DEVICE-NAME>)}
show ipv6 route {<IF-NAME>|ge <1-X>|me1|port-channel <1-2>|ppppoe1|serial <1-4>|
t1e1 <1-4> <1-1>|up|vlan <1-4095>|wwan1|xge} {(on <DEVICE-NAME>)}
Parameters
{on <DEVICE-NAME>}
ipv6Displays IPv6 related information and statistical data
default-gatewaysDisplays all learnt default gateways
delegated-prefixDisplays prefix delegation information
hop-limitDisplays the configured IPv6 hop count value
name-serverDisplays DNS name servers
on <DEVICE-NAME>This parameter is common to all of the above keywords.
  • on <DEVICE-NAME> – Optional. Displays the specified information on a device (access point, wireless controller, or service platform)
    • <DEVICE-NAME> – Specify the name of the AP, wireless controller, or service platform.
show ipv6 dhcp [client received-options|relay status|status] {on <DEVICE-NAME>}
dhcpDisplays DHCPv6 related information
client received-optionsDisplays DHCP options received from clients
relay statusDisplays the DHCPv6 relay agent‘s running status
statusDisplays the DHCPv6 stateless server daemon‘s status. In case the DHCPv6 server is up and running, it also displays interface names.
interface {<IF-NAME>|brief}Displays IPv6 status and configuration on a specified interface related information
  • <IF-NAME> – Optional. Specify the interface name.
    • brief – Optional. Displays a brief summary of IPv6 status and configuration on the specified interface
{on <DEVICE-NAME>}
mld snoopingDisplays Multicast Listener Discovery Protocol (MLD) snooping related information
mrouter vlan <1-4095>Displays IPv6 multicast router information on the specified VLAN
querier vlan <1-4095>Displays IPv6 multicast querier information on the specified VLAN
vlan <1-4095>Displays MLD snooping related information on the specified VLAN
neighbors <VLAN-NAME>Displays IPv6 neighbors on the specified VLAN
on <DEVICE-NAME>Optional. Displays IPv6 neighbors on a specified device (access point, wireless controller, or service platform)
routeDisplays IPv6 route table
<IF-NAME>Optional. Displays IPv6 route table for the interface identified by the <IF-NAME> keyword
ge <1-X>Optional. Displays IPv6 route table for the selected GigabitEthernet interface
me1Optional. Displays IPv6 route table for the FastEthernet interface
port-channel <1-2>Optional. Displays IPv6 route table for the selected port-channel interface
pppoe1Optional. Displays IPv6 route table for the PPP over Ethernet interface
vlan <1-4095>Optional. Displays IPv6 route table for the selected VLAN interface
upOptional. Displays IPv6 route table for the WAN Ethernet interface
wwanOptional. Displays IPv6 route table for the wireless WAN interface
xge <1-4>Optional. Displays IPv6 route table for the selected TenGigabitEthernet interface
rfs4000-229D58(config)#show ipv6 route
      DESTINATION            GATEWAY           FLAGS            INTERFACE
      2000:abcd::/64       fe80::300:1       S                vlan300
      default              fe80::11:1        R                vlan11
      4444:1111::/64       direct            C                vlan1
Flags:  C - Connected G - Gateway S - Static R - IPv6-RA
rfs4000-229D58#show ipv6 default-gateways
 Source: IPv6-RA                  Gateway-address : fe80::100:1
         Preference: medium           Status      : not-monitored
         Installed : NO               Interface   : vlan100
         Remaining Lifetime: 1471 sec
 Source: IPv6-RA                  Gateway-address : fe80::1:2
         Preference: low              Status      : not-monitored
         Remaining Lifetime: 1488 sec
 Source: Static-Route             Gateway-address : fe80::2000:1
         Preference: NA               Status      : unreachable
         Installed : NO               Interface   : vlan2000
         Remaining Lifetime: forever
 Source: IPv6-RA                  Gateway-address : fe80::11:1
         Preference: high             Status      : reachable
         Installed : YES              Interface   : vlan11
rfs4000-229D58#
