To migrate to the passpoint policy configuration mode, use the following command:
<DEVICE>(config)#passpoint-policy <POLICY-NAME>
nx9500-6C8809(config)#passpoint-policy test
nx9500-6C8809(config-passpoint-policy-test)#?
Passpoint Policy Mode commands:
3gpp Configure a 3gpp plmn (public land mobile network) id
access-network-type Set the access network type for the hotspot
connection-capability Configure the connection capability for the hotspot
domain-name Add a domain-name for the hotspot
hessid Set a homogeneous ESSID value for the hotspot
internet Advertise the hotspot having internet access
ip-address-type Configure the advertised ip-address-type
nai-realm Configure a NAI realm for the hotspot
net-auth-type Add a network authentication type to the hotspot
no Negate a command or set its defaults
operator Add configuration related to the operator of the
hotspot
osu Online signup
roam-consortium Add a roam consortium for the hotspot
venue Set the venue parameters of the hotspot
wan-metrics Set the wan-metrics of the hotspot
clrscr Clears the display screen
commit Commit all changes made in this session
do Run commands from Exec mode
end End current mode and change to EXEC mode
exit End current mode and down to previous mode
help Description of the interactive help system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to memory or terminal
Section contents:
