no (bgp-router-config)
Removes the BGP router settings
Syntax
no [aggregate-address|bgp|bgp-route-limit|distance|ip|network|route-redistribute|timers]
Parameters
no <PARAMETERS>
no <PARAMETERS>Removes the BGP router settings based on the parameters passed
The following example shows the BGP router settings before the ‘no‘ commands have been executed:
nx9500-6C8809(config-device B4-C7-99-6C-88-09-router-bgp)#show context
 router bgp
  bgp enable
  asn 1
  aggregate-address 116.117.118.0/24 as-set summary-only
  bgp neighbor 192.168.13.199
   remote-as 1
   use route-map UnSupMap_01 in
  bgp neighbor 192.168.13.99
   remote-as 199
   maximum-prefix 9999 80 restart 50
  bgp-route-limit num-routes 10 reset-time 360
nx9500-6C8809(config-device B4-C7-99-6C-88-09-router-bgp)#no bgp neighbor 192.168.13.99
nx9500-6C8809(config-device B4-C7-99-6C-88-09-router-bgp)#no aggregate-address 116.117.118.0/24
nx9500-6C8809(config-device B4-C7-99-6C-88-09-router-bgp)#no bgp-route-limit
The following example shows the BGP router settings after the ‘no‘ commands have been executed:
 router bgp
  bgp enable
  asn 1
   remote-as 1
