This chapter summarizes the Roaming Assist Policy commands in the CLI command structure.
By constantly monitoring a client's packets and the RSSI (received signal strength indicator) of a given client by a group of access points, decision can be made on the optimal access point to which the client needs to roam. Then forcefully direct the client to the optimal access point.
The threshold intervals are configurable and can be adjusted based on the client load.
Use the (config) instance to configure a roaming assist policy. To navigate to the roaming assist policy configuration instance, use the following commands:
<DEVICE> (config) roaming-assist-policy <ROAMING-ASSIST-POLICY-NAME>
nx9500-6C8809(config)roaming-assist-policy test nx9500-6C8809(config-roaming-assist-policy-test)#? Roaming Assist Mode commands: action Configure action - action is deauth / log / assisted-roam aggressiveness Configure the roaming aggressiveness for a wireless client detection-threshold Configure the detection threshold - when exceeded, client monitoring starts disassoc-time Configure the disassociation time - time after which a disassociation is sent handoff-count Configure the handoff count - number of times client can exceed handoff threshold handoff-threshold Configure the handoff threshold - when exceeds an action is taken. monitoring-interval Configure the monitoring interval - interval at which client monitoring occurs no Negate a command or set its defaults sampling-interval Configure the sampling interval - interval at which client rssi values are checked clrscr Clears the display screen commit Commit all changes made in this session end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-roaming-assist-policy-test)#
Section contents:
