hysteresis (meshpoint-device-config)
Configures path selection SNR hysteresis values on this meshpoint-device (access point). These are settings that facilitate dynamic path selection. Configuring hysteresis prevents frequent re-ranking of the shortest path cost.
Syntax
hysteresis [min-threshold|period|root-sel-snr-delta|snr-delta]
hysteresis [min-threshold <-100-0>|period <0-600>|root-sel-snr-delta <1-100>|
snr-delta <1-100>]
Parameters
snr-delta <1-100>]
min-threshold <-100-0>Configures the minimum signal strength that a device should have to be considered a likely candidate in the mesh route (to the mesh root node) selection process.
  • <-100-0> – Specify a value from -100 - 0 dB. The default is 0 dB.
period <0-600>
Configures the interval, in seconds, for which a likely candidate‘s path method hysteresis is sustained. In other words a device capable of sustaining the signal strength for the specified period of time is a likely candidate in the mesh route (to the mesh root node) selection process.
  • <0-600> – Specify a value from 0 - 600 seconds. The default is 1 second.
Configures the signal strength, in dB, that a device has to sustain, within the delta range, to be considered a likely candidate in the mesh route (to the mesh root node) selection process.
  • <1-100> – Specify a value from 1 - 100 dB.
snr-delta <1-100>
Configures the SNR delta. The device with must have a SNR of a greater delta than its current neighbor to be considered a likely candidate in the mesh route (to the mesh root) selection process.
  • <1-100> – Specify a value from 1 - 100 dB. The default is 1 dB.
rfs4000-229D58
(config-profile-testAP71XX-meshpoint-test)#hysteresis period 15
rfs4000-229D58
(config-profile-testAP71XX-meshpoint-test)#hysteresis root-sel-snr-delta 12
rfs4000-229D58
(config-profile-testAP71XX-meshpoint-test)#hysteresis snr-delta 3
rfs4000-229D58
(config-profile-testAP71XX-meshpoint-test)#hysteresis min-threshold -65
rfs4000-229D58
(config-profile-testAP71XX-meshpoint-test)#show context
 meshpoint-device test
rfs4000-229D58
Related Commands
no (meshpoint-device-config)
Removes the configured path selection SNR hysteresis values
